Intel Core i5-10500 recenzija
· · Procesori · Stranica 4 od 5
Rezultati testiranja – drugi dio
Grafičke performanse @ Gigabyte RX 5700 XT Gaming OC
2560 x 1440
Borderlands 3 (Badass)Core i7-8700K: 62,39Core i7-8700K62,39Core i5-10500: 61,88Core i5-1050061,88Ryzen 9 3900X: 61,05Ryzen 9 3900X61,05Ryzen 3 3300X: 60,92Ryzen 3 3300X60,92Ryzen 3 3100: 60,86Ryzen 3 310060,86069
F1 2019 (Ultra)Ryzen 9 3900X: 134Ryzen 9 3900X134Core i5-10500: 133Core i5-10500133Core i7-8700K: 133Core i7-8700K133Ryzen 3 3300X: 128Ryzen 3 3300X128Ryzen 3 3100: 125Ryzen 3 31001250147
Far Cry 5 (Ultra)Core i5-10500: 101Core i5-10500101Core i7-8700K: 101Core i7-8700K101Ryzen 9 3950X: 99Ryzen 9 3950X99Ryzen 3 3300X: 97Ryzen 3 3300X97Ryzen 9 3900X: 96Ryzen 9 3900X96Ryzen Threadripper 3970X: 95Ryzen Threadripper 3970X95Ryzen 3 3100: 88Ryzen 3 3100880111
Ghost Recon Breakpoint (DX11, Ultra)Core i5-10500: 81Core i5-1050081Core i7-8700K: 80Core i7-8700K80Ryzen 9 3900X: 78Ryzen 9 3900X78Ryzen 3 3300X: 77Ryzen 3 3300X77Ryzen 3 3100: 72Ryzen 3 310072089
Ghost Recon Breakpoint (Vulkan, Ultra)Core i5-10500: 86Core i5-1050086Core i7-8700K: 86Core i7-8700K86Ryzen 9 3900X: 86Ryzen 9 3900X86Ryzen 3 3300X: 86Ryzen 3 3300X86Ryzen 3 3100: 84Ryzen 3 310084095
Hitman (Ultra)Core i7-8700K: 119,54Core i7-8700K119,54Core i5-10500: 118,69Core i5-10500118,69Ryzen 9 3900X: 117,82Ryzen 9 3900X117,82Ryzen 9 3950X: 116,65Ryzen 9 3950X116,65Ryzen 3 3300X: 115,2Ryzen 3 3300X115,2Ryzen Threadripper 3970X: 115,11Ryzen Threadripper 3970X115,11Ryzen 3 3100: 110,56Ryzen 3 3100110,560131
The Division 2 (Ultra)Core i5-10500: 65Core i5-1050065Core i7-8700K: 65Core i7-8700K65Ryzen 3 3300X: 65Ryzen 3 3300X65Ryzen 9 3900X: 65Ryzen 9 3900X65Ryzen Threadripper 3970X: 65Ryzen Threadripper 3970X65Ryzen 9 3950X: 64Ryzen 9 3950X64Ryzen 3 3100: 63Ryzen 3 310063072
Intel i dalje demonstrira visoke gaming performanse čak i s procesorom koji nije u vrhu ponude. Relativno visoki radni taktovi od preko 4,0 GHz zaslužni su za izvlačenje maksimalnih performansi iz grafike. Naravno, razlike nisu velike i drastične  i jedini procesor koji je stvarno u deficitu je Ryzen 3 3100, no on je i puno jeftiniji.
Memorijske performanse @ 3.200 MHz CL15
AIDA64 RAM ReadCore i7-8700K: 47.016Core i7-8700K47.016Core i5-10500: 46.309Core i5-1050046.309051.718
AIDA64 RAM WriteCore i5-10500: 46.625Core i5-1050046.625Core i7-8700K: 45.941Core i7-8700K45.941051.288
AIDA64 RAM CopyCore i7-8700K: 41.892Core i7-8700K41.892Core i5-10500: 38.500Core i5-1050038.500046.081
AIDA64 RAM LatencyCore i5-10500: 44,5Core i5-1050044,5Core i7-8700K: 49,8Core i7-8700K49,8055
U odnosu na i7-8700K s memorijske performanse tu negdje, s tim da i5-10500 ima niže vrijeme pristupa memoriji što je vrlo bitno.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadRyzen 3 3300X: 51.794Ryzen 3 3300X51.794Core i5-10500: 51.131Core i5-1050051.131Ryzen 3 3100: 50.948Ryzen 3 310050.948056.973
AIDA64 RAM WriteCore i5-10500: 51.767Core i5-1050051.767Ryzen 3 3100: 28.799Ryzen 3 310028.799Ryzen 3 3300X: 28.799Ryzen 3 3300X28.799056.944
AIDA64 RAM CopyRyzen 3 3100: 47.833Ryzen 3 310047.833Ryzen 3 3300X: 47.758Ryzen 3 3300X47.758Core i5-10500: 43.081Core i5-1050043.081052.616
AIDA64 RAM LatencyCore i5-10500: 46,9Core i5-1050046,9Ryzen 3 3300X: 65,8Ryzen 3 3300X65,8Ryzen 3 3100: 70,3Ryzen 3 310070,3077
U usporedbi s AMD-ovim procesorima na višoj frekvenciji memorije pokazuje nadmoć u zapisu i ponovno u vrlo niskom vremenu pristupa gdje potpuno deklasira Ryzene.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Core i5-10500: 124Core i5-10500124Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 3 3100: 146Ryzen 3 3100146Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 5 3600X: 162Ryzen 5 3600X162Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 3 3300X: 163Ryzen 3 3300X163Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 7 1800X: 173Ryzen 7 1800X173Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 3950X: 230Ryzen 9 3950X2300253
Potrošnja sistema je niska zbog načina na koji se ponaša kontrola frekvencije ovoga procesora. Pod opterećenjem all core turbo kreće s oko 4,2 GHz, da bi vrlo brzo pao na 3,7 pa na 3,5 i na kraju se zadržavao između 3,3 i 3,4 GHz u dugotrajnom radu. Kao što smo napisali, tweakanjem se može dobiti dugotrajni boost takt od oko 4,1 GHz no to ne uzimamo kao mjerilo, jer to prosječan korisnik neće raditi. Samo za usporedbu, tada potrošnja raste na 150W.
Zagrijavanje @ Noctua D15
TemperatureCore i5-10500: 68Core i5-1050068Ryzen 3 3100: 69,6Ryzen 3 310069,6Ryzen 3 3300X: 74,9Ryzen 3 3300X74,9Ryzen 5 3600X: 77,3Ryzen 5 3600X77,3Ryzen 9 3900X: 78,7Ryzen 9 3900X78,7Ryzen 7 3700X: 81,3Ryzen 7 3700X81,3089
S obzirom na nizak radni takt pod dugotrajnim opterećenjem ni zagrijavanje nije visoko, pa je zapravo D15 overkill za ovaj procesor. Maksimum na jednoj jezgri je bio 68°C, a prosjek maksimuma na svima 66.8°C. Ipak, prosječna temperatura u dugotrajnom se radu kreće na oko 55°C.
Stranica 4 od 5
