Intel Core i5-10600K recenzija
· · Procesori · Stranica 5 od 6
Rezultati testiranja – treći dio
Porast performansi overclockingom
PCMarkCore i5-10600K @ OC: 6.278Core i5-10600K @ OC6.278Core i5-10600K: 6.067Core i5-10600K6.06706.906
Cinebench 15Core i5-10600K @ OC: 1.593Core i5-10600K @ OC1.593Core i5-10600K: 1.415Core i5-10600K1.41501.752
Cinebench 20Core i5-10600K @ OC: 3.934Core i5-10600K @ OC3.934Core i5-10600K: 3.592Core i5-10600K3.59204.327
CoronaCore i5-10600K @ OC: 124Core i5-10600K @ OC124Core i5-10600K: 134Core i5-10600K1340147
V-RayCore i5-10600K @ OC: 81Core i5-10600K @ OC81Core i5-10600K: 89Core i5-10600K89098
wPrime v2.10Core i5-10600K @ OC: 106,863Core i5-10600K @ OC106,863Core i5-10600K: 118,862Core i5-10600K118,8620131
Najveća snaga ovog procesora je njegov otključan množitelj i činjenica da se bez većih problema može koristiti 24/7 na 5,0 GHz uz uvjet da mu se osigura dobro hlađenje. Skok performansi kod porasta takta s 4,5 GHz na 5,0 GHz je odličan i ubacuje ovaj procesor u potpuno novu ligu u odnosu na 10400 i 10500 modele.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadRyzen 3 3300X: 51.794Ryzen 3 3300X51.794Core i5-10600K: 51.205Core i5-10600K51.205Core i5-10500: 51.131Core i5-1050051.131Core i5-10400: 51.080Core i5-1040051.080Ryzen 3 3100: 50.948Ryzen 3 310050.948056.973
AIDA64 RAM WriteCore i5-10600K: 51.873Core i5-10600K51.873Core i5-10500: 51.767Core i5-1050051.767Core i5-10400: 51.474Core i5-1040051.474Ryzen 3 3100: 28.799Ryzen 3 310028.799Ryzen 3 3300X: 28.799Ryzen 3 3300X28.799057.060
AIDA64 RAM CopyRyzen 3 3100: 47.833Ryzen 3 310047.833Ryzen 3 3300X: 47.758Ryzen 3 3300X47.758Core i5-10600K: 45.223Core i5-10600K45.223Core i5-10400: 43.124Core i5-1040043.124Core i5-10500: 43.081Core i5-1050043.081052.616
AIDA64 RAM LatencyCore i5-10400: 46,7Core i5-1040046,7Core i5-10500: 46,9Core i5-1050046,9Core i5-10600K: 47,1Core i5-10600K47,1Ryzen 3 3300X: 65,8Ryzen 3 3300X65,8Ryzen 3 3100: 70,3Ryzen 3 310070,3077
Uz ovaj jači procesor ima smisla nabavka i brže memorije, jer će svakako to rezultirati i boljim ukupnim performansama. Performanse propusnosti i vrijeme pristupa je kao što vidimo slično kao i kod druga dva Core procesora.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Core i5-10500: 124Core i5-10500124Core i5-10400: 125Core i5-10400125Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 3 3100: 146Ryzen 3 3100146Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 5 3600X: 162Ryzen 5 3600X162Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 3 3300X: 163Ryzen 3 3300X163Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Core i5-10600K: 167Core i5-10600K167Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 7 1800X: 173Ryzen 7 1800X173Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 3950X: 230Ryzen 9 3950X2300253
Potrošnja sistema s Large Data postavci OCCT-a se kreće na razumnih 167 W, što vrijedi i za sve ostale benchmarke i aplikacije koje smo isprobali. Samo za usporedbu sa Small Data potrošnja raste na 226 W što nije realno opterećenje.
Zagrijavanje @ Noctua D15
TemperatureCore i5-10400: 58Core i5-1040058Core i5-10500: 68Core i5-1050068Ryzen 3 3100: 69,6Ryzen 3 310069,6Core i5-10600K: 70Core i5-10600K70Ryzen 3 3300X: 74,9Ryzen 3 3300X74,9Ryzen 5 3600X: 77,3Ryzen 5 3600X77,3Ryzen 9 3900X: 78,7Ryzen 9 3900X78,7Ryzen 7 3700X: 81,3Ryzen 7 3700X81,3089
Maksimalno zagrijavanje jedne jezgre pod Noctuom D15 je solidnih 70°C što se ponavlja i tijekom svih ostalih benchmarka. Prosjek na svim jezgrama je iznosio 65.33°C.
Kod Small Data testa u OCCT-u temperatura raste na maksimalnih 80°C za jednu jezgru. Prosjek na svim jezgrama je iznosio 77°C.
Stranica 5 od 6
