Intel Core i7-875K & i5-655K – otključani dvojac
Zaključak – Conclusion
Intel je ponudom ova dva procesora u susret izašao overclockerima
koji nemaju duboke džepove za vrlo skupi 980X procesor. Napokon i što su do
sada čekali, rekli bi. Izravan je to napad na AMD-ove 1090T i 965 modele kojima,
kao što smo vidjeli iz testova mogu relativno lako parirati. 655K ima doduše
niže performanse od X4 965 procesora, što nadoknađuje tek overclockingom (da
smo OC-ali 965-icu situacija bi ponovno bila ista). 875K je s toga bolji izbor,
jer u svemu parira šestjezgrenom 1090T a kada overclockiramo porast
performansi je odličan. Bolji je to izbor (od 655K) i zbog činjenice da mu
je cijena skoro diskontna (opet za napad na AMD). Za 184 USD je jeftiniji
od preskupog i7-870 i time postaje vrlo pristupačan širem krugu kupaca. Ukoliko
pogledamo odnos snage i performansi kod usporedivih AMD i Intel procesora
vidjeti ćemo da su stvari oko ili na nuli. Prevagnuti će vjerojatno cijena
matičnih ploča te osobni afiniteti kupca (možda kod nekoga i niža potrošnja
električne energije u slučaju Intel procesora).
Conclusion
By launching these two CPU`s Intel is trying to satisfy overclockers
who do not have a lot of money for the very expensive 980X processor. Finally,
we would say and what have they been waiting for so long? This is a direct
attack on AMD’s X4 965 models and X6 1090T models both with the level of performance
and price. 655K is indeed a bit slower than the Phenom X4 965 processor, which
is compensated only with overclocking (but with overclocking of 965 the situation
would again be the same). 875K is therefore a better choice (than 655K), because
it can easily compete with 1090T, and increase in performance with overclocking
is excellent. It is a great CPU which has a great price (again attack on AMD).
It is 184 USD cheaper than overpriced i7-870 and thus becomes very accessible
to a wider circle of customers. If you look at the price/performance ratio
between comparable AMD and Intel processors, you can see that things even
out in this situation. What is likely to prevail, is the motherboard price
and personal affinities of the customer (Intel CPU lower power consumption
may even be the deciding point for someone).
Stranica 5 od 5
