Intel i7-6700K test
· · Procesori · Stranica 5 od 7
Rezultati testova – drugi dio
x.264 Benchmark v4.0i7-6700K: 215,1i7-6700K215,1i7-4790K: 210,23i7-4790K210,23i7-4960X: 201,82i7-4960X201,82i7-5960X: 200,42i7-5960X200,42i5-4670K: 197,08i5-4670K197,08i7-5930K: 196,21i7-5930K196,21i7-5820K: 194,29i7-5820K194,29i7-4770K: 188,97i7-4770K188,97i7-3960X: 187,88i7-3960X187,88i7-3770K: 177,08i7-3770K177,080237
6700K je ovdje na vrhu – odličan rezultat.
x.264 Benchmark v5.0i7-5930K: 92,30i7-5930K92,30i7-5960X: 91,94i7-5960X91,94i7-5820K: 89,84i7-5820K89,84i7-6700K: 78,18i7-6700K78,18i7-4770R: 72,21i7-4770R72,21i5-4670K: 62,63i5-4670K62,630102
Noviji x.264 benchmark malo drugačije radi pa su i performanse drugačije, no 6700K se sasvim solidno drži.
LuxMark v.2.0i7-5960X: 652i7-5960X652Radeon R7 260X: 644Radeon R7 260X644Radeon R7 260: 544Radeon R7 260544i7-5930K: 513i7-5930K513i7-5820K: 509i7-5820K509i7-4960X: 495i7-4960X495i7-3960X: 480i7-3960X480i7-6700K: 424i7-6700K424i7-4770R: 370i7-4770R370A10-7850K GPU: 286A10-7850K GPU286A10-7800 GPU: 263A10-7800 GPU263A8-7600 GPU: 232A8-7600 GPU2320717
Luxmark performanse x86 jezgri su zapravo jako solidne u odnosu na šestjezgrene modele.
wPrime 2.0i7-5960X: 116,929i7-5960X116,929i7-4960X: 129,637i7-4960X129,637i7-3960X: 135,127i7-3960X135,127i7-5930K: 136,293i7-5930K136,293i7-5820K: 140,245i7-5820K140,245i7-3930K: 164,566i7-3930K164,566i7-6700K: 178,347i7-6700K178,347i7-4790K: 186,468i7-4790K186,468i7-4770K: 195,174i7-4770K195,174i7-3770K: 198,092i7-3770K198,092i7-2600K: 225i7-2600K225FX-8150: 275,996FX-8150275,996i5-2500K: 321,608i5-2500K321,6080354
Za kraj CPU testova je dobro stari wPrime u kojem 6700K ponovno izlazi kao lagani pobjednik ispred Devil˙s Canyona.
Gaming performanse
Alien Isolationi7-6700K: 71,14i7-6700K71,14i7-3960X @ 4.5GHz: 70,52i7-3960X @ 4.5GHz70,52072
Bioshock Infinitei7-6700K: 61,35i7-6700K61,35i7-3960X @ 4.5GHz: 61,14i7-3960X @ 4.5GHz61,14062
Hitman Absolutioni7-6700K: 34,33i7-6700K34,33i7-3960X @ 4.5GHz: 34,2i7-3960X @ 4.5GHz34,2035
Skylake ima odlične igračke performanse ukoliko ga usporedimo s naclockanim i7-3960X procesorom, pri čemu je grafička kartica bila Gigabyteova GTX950 OC. Testove smo proveli na identičan način kao kod testa dotične kartice pri rezoluciji od 1920 x 1200. Samo ćemo spomenuti kako je pri opterećenju Sandy Bridge-E sistem trošio 326W, a Skylake 175W.
Stranica 5 od 7
