Leadtek WinFast DTV Dongle H – kronični nedostatak teletexta
· · Video · Stranica 3 od 3
Zaključak – Conclusion
Leadtek
WinFast DTV Dongle H je jednostavan i korisnički susretljiv USB tuner kojeg
prati izvrsna WinFast DTV2 aplikacija. Nažalost, u Hrvatskoj smo ograničeni
na praćenje 4 kanala i jednog HD promo kanala, barem što se tiče digitalne televizije.
Nedostaci ovog tunera su slaba antena, čiji je prijam loš i nemogućnost pregledavanja
teletexta, iako tu funkciju drugi tuneri imaju. Što se tiče kvalitete slike,
ona je odlična jer se tu ipak radi o digitalnom signalu koji omogućava jako
dobru kvalitetu slike, bez snijega ili šuma. Slika ostaje kvalitetna i ako je
signal slab, ako je signal preslab slika i zvuk počinju zastajkivati dok se
kod analognog prijema pojavi poznati snijeg na slici. Ovaj tuner Vam mođemo
preporučiti iz više razloga (ukoliko izuzmemo činjenicu da teletekst ne radi).
Malen je te ga je jednostavno nositi u torbi uz prijenosnik, dobro radi, prati
ga solidan software te ima dobar daljinski upravljač.
Conclusion
The
Leadtek WinFast DTV Dongle H is a simple and user friendly USB TV tuner which
uses the excellent WinFast DTV2 application. The following drawbacks are: the
software’s inability to present the teletext to the user (this maybe happens
only in Croatia, so don’t take this for granted if you live in another country)
and the poor antenna. The video quality is excellent because there is now fuzziness
on digital TV, not to mention the snowy screens which can’t appear because of
the DTV technology. If the signal is too weak, the picture and sound will start
to break up and eventually disappear – simple as that. If the signal level is
sufficient enough, you will have the same quality as if the signal is at its
maximum level. We can recommend this product for several reasons (if we exclude
that TTX is not operational). It`s small, easy to carry around, it works very
well, software is very good and remote control is good.
Stranica 3 od 3
