Terratec Aureon Sky i Logitech Z-560
· · Audio · Stranica 12 od 13
RMAA bench
Cijeli test
Kad bismo išli napraviti cijeli test sa svim slikama od sve tri
zvučne kartice, članak bi jednostavno bio predug pa vam prilažen cijeli test
samo od TerraTec Aureon Sky kartice i to kod sampliranja pri 32-bit i 96 kHz.
Aureon Wave
RightMark Audio Analyzer test
Testing chain: External loopback (line-out – line-in)
Sampling mode: 32-bit, 96 kHz
Summary
Frequency response (from 40 Hz
to 15 kHz), dB:
+0.02, -0.11 Odličan
Noise level, dB (A): -98.3 Odličan
Dynamic range, dB (A): 95.8 Odličan
THD, %: 0.0064 Vrlo dobar
IMD, %: 0.0065 Vrlo dobar
Stereo crosstalk, dB: -90.5 Odličan
Generalna ocjena: Odličan
Frequency response
Spectrum graph
Frequency range Response
From 20 Hz to 20 kHz, dB -0.52, +0.02
From 40 Hz to 15 kHz, dB -0.11, +0.02
Noise level
Spectrum graph
Parameter Left Right
RMS power, dB: -92.1 -91.5
RMS power (A-weighted), dB: -98.3 -97.6
Peak level, dB FS: -79.9 -79.4
DC offset, %: 0.00 0.00
Dynamic range
Spectrum graph
Dynamic range, dB: +90.5 +90.1
Dynamic range (A-weighted), dB: +95.3 +95.9
DC offset, %: -0.00 -0.00
THD + Noise (at -3 dB FS)
Spectrum graph
THD, %: 0.009 0.006
THD + Noise, %: 0.010 0.007
THD + Noise (A-weighted), %: 0.011 0.009
Intermodulation distortion
Spectrum graph
IMD + Noise, %: 0.006 0.007
IMD + Noise (A-weighted), %: 0.005 0.006
Stereo crosstalk
Spectrum graph
Parameter L <- R L -> R
Crosstalk at 100 Hz, dB: -81 -83
Crosstalk at 1 kHz, dB: -89 -86
Crosstalk at 10 kHz, dB: -84 -86
RMAA bench
Stranica 12 od 13
