Xiaomi Mi Mix Prime – mini recenzija
· · Mobilno · Stranica 2 od 3
Mi Mix Prime – drugi dio
Performanse
PCMark (Work 2.0)Huawei Mate 9: 5.817Huawei Mate 95.817Honor 8: 5.469Honor 85.469Huawei P9: 5.248Huawei P95.248Xiaomi Mi Mix Prime: 5.234Xiaomi Mi Mix Prime5.234Xiaomi Mi5s: 5.125Xiaomi Mi5s5.125Sony Xperia XZ: 4.969Sony Xperia XZ4.969Sony Xperia X Compact: 4.881Sony Xperia X Compact4.881Sony Xperia Z5 Compact: 4.292Sony Xperia Z5 Compact4.29206.399
3DMark Sling Shot ExtremeXiaomi Mi Mix Prime: 2.510Xiaomi Mi Mix Prime2.510Sony Xperia XZ: 2.472Sony Xperia XZ2.472Sony Xperia Z5 Compact: 1.662Sony Xperia Z5 Compact1.662Honor 8: 887Honor 8887Sony Xperia X Compact: 854Sony Xperia X Compact85402.761
BaseMark OS IIApple iPhone 7 Plus: 3.281Apple iPhone 7 Plus3.281Apple iPhone 7: 2.797Apple iPhone 72.797Apple iPhone 6S: 2.232Apple iPhone 6S2.232Sony Xperia XZ: 2.165Sony Xperia XZ2.165Xiaomi Mi Mix Prime: 2.035Xiaomi Mi Mix Prime2.035HTC 10: 1.994HTC 101.994Honor 8: 1.953Honor 81.953Sony Xperia Z5 Compact: 1.841Sony Xperia Z5 Compact1.841Sony Xperia X Compact: 1.829Sony Xperia X Compact1.829Sony Xperia Z5 Premium: 1.532Sony Xperia Z5 Premium1.532Apple iPhone 6: 1.332Apple iPhone 61.33203.609
Geekbench 4 (single-core score)Hauwei Mate 9: 1.942Hauwei Mate 91.942Xiaomi Mi Mix Prime: 1.825Xiaomi Mi Mix Prime1.825Xiaomi Mi5s: 1.801Xiaomi Mi5s1.801Huawei P9: 1.726Huawei P91.726Honor 8: 1.693Honor 81.693Sony Xperia XZ: 1.581Sony Xperia XZ1.581Sony Xperia X Compact: 1.394Sony Xperia X Compact1.394Sony Xperia Z5 Compact: 1.361Sony Xperia Z5 Compact1.361Dell Venue 8 7840: 1.079Dell Venue 8 78401.079Huawei T2 8 Pro: 623Huawei T2 8 Pro62302.136
Geekbench 4 (multi-core score)Huawei Mate 9: 5.864Huawei Mate 95.864Honor 8: 5.324Honor 85.324Huawei P9: 4.695Huawei P94.695Xiaomi Mi5s: 4.262Xiaomi Mi5s4.262Sony Xperia XZ: 4.217Sony Xperia XZ4.217Xiaomi Mi Mix Prime: 3.842Xiaomi Mi Mix Prime3.842Sony Xperia X Compact: 3.410Sony Xperia X Compact3.410Dell Venue 8 7840: 3.074Dell Venue 8 78403.074Sony Xperia Z5 Compact: 2.257Sony Xperia Z5 Compact2.257Huawei T2 8 Pro: 1.928Huawei T2 8 Pro1.92806.450
Geekbench 4 (render script)Sony Xperia XZ: 7.122Sony Xperia XZ7.122Xiaomi Mi Mix Prime: 6.899Xiaomi Mi Mix Prime6.899Sony Xperia Z5 Compact: 3.728Sony Xperia Z5 Compact3.728Sony Xperia X Compact: 3.385Sony Xperia X Compact3.385Huawei P9: 3.195Huawei P93.195Honor 8: 3.119Honor 83.11907.834
Performanse su mu na samom vrhu (za sada :D). Pokreće ga Snapdragon 821 procesor (MSM8996 Pro) s četiri Kryo jezgre na 2,35 GHz uz podršku grafičkog čipa Adreno 530 @ 653 MHz u kombinaciji s 6 GB LPDDR 4 dvokanalne radne memorije (1866 MHz). Ne podržava memorijske kartice, ali s 256 GB UFS 2.0 kapaciteta interne memorije MicroSD nije ni potrebna. U cjelini, vrlo je energičan u svakodnevnom radu i nosi se sa svim zadacima od pokretanja aplikacija, multitaskinga, preko pregledavanje weba do uređivanje slika ili videa i bilo koje vrste multimedijske reprodukcije. Za povezivanje na popisu su: Bluetooth 4.2 (+BT HID), dual-band Wi-Fi 802.11ac, GPS (A-GPS i GLONASS), digitalni kompas, DAC visoke audio razlučivost na 24-bit / 192 kHz, USB tip C sučelje, NFC i LTE modem Cat 12 / 13 brzina. Baterija
Baterija je kapaciteta 4400 mAh s podrškom za Quick Charge 3.0 brzo punjenje. Nije problem da zadovolji potrebu rada uređaja od jednog dana. Uz originalni punjač može se napuniti za dva sata. Miui
Ovaj dio recenzije uskoro će biti zastario jer je u pripremi je  MIUI 9 temeljen na Android 7.0 inačici. Trenutno uređaj pokreće MIUI Global 8.0.6.0.0 firmware. Pročišćen je od kineskih aplikacija, podržava hrvatski jezik i ima sve Google aplikacije i Play servis kao standard.
Ima puno mogućnosti prilagodbe i ikone aplikacija pojavljuju se na početnim zaslonima jer nema zasebne aplikacijske ladice. Obavijesti se mogu aktivirati  prelaskom prsta bilo gdje na zaslonu.  UI uključuju opciju upotrebe uređaja jednom rukom koje će po uključivanju smanjiti čitav prikaz na  minimalno 3,5 inča.
Također, za olakšani rad jednom rukom nudi se plutajući widget, možda bolje reći virtualna proširiva tipka (pod nazivom “pametna lopta”) koja donosi  neke funkcionalnosti za brzi pristup i ima mogućnost postavljanja bilo gdje na zaslonu. Kalkulator je bogat opcijama, a surfati webom ugodno je iskustvo ma koji god web preglednik koristili. Ne bi se više zadržavali na detaljima sustava i UI  jer ih možete pročitati u recenziji Xiaomi Mi 5s Plus.
Stranica 2 od 3
