Thief – Mantle testovi sa tri grafičke
Datum objave 04.04.2014 - Krešimir Matanović
Najprije malo o Mantleu
Kao što smo u uvodu napisali, Mantle performanse na novom Thiefu smo testirali uz pomoć tri grafičke kartice i dvije platforme. Sve tri kartice su bile Sapphireove - R7 240 LP, R7 265 Dual-X i R9 290 Tri-X. Kako bi uopće mogli doći do Mantlea potrebno ga je bilo otključati na Steamu uz pomoć Press pass-a, te isto tako instalirati Catalyst 14.3 beta drivere. Nakon toga se u Thiefu otvara mogućnost korištenja Mantela kao API-a.
AMD navodi i neke poznate probleme koji su prisutni u ovoj fazi i koji će se s vremenom ispraviti, a donosimo ih u izvornom engleskom:
- Multi-GPU support under the Mantle codepath will be added to Thief in a future application patch
- Mantle performance for GPUs with 2GB framebuffers will receive additional optimization in a future application path for Thief. These products may see limited gains in scenarios requiring large amount of video memory (such as high quality settings with SuperSampling Anti-Aliasing enabled), and performance optimizations are under investigation.
- Low-overhead validation i procesuiranje API naredbi
- Explicit command buffer control
- Close to linear performance scaling from reordering command buffers onto multiple CPU cores
- Reduced runtime shader compilation overhead
- Reduction of command buffers submissions
- Explicit control of resource compression, expands and synchronizations
- Asynchronous DMA queue for data uploads independent from the graphics engine
- Asynchronous compute queue for overlapping of compute and graphics workloads
- Data formats optimizations via flexible buffer/image access
- Advanced Anti-Aliasing features for MSAA/EQAA optimizations
Testovi
Kao što smo u uvodu napisali, testirali smo na dvije platforme. Intel platforma (i7-3960X @ 4.5GHz), nije donijela napretka ili tek vrlo mali kada smo smanjili razinu detalja. No, kada smo se okrenuli AMD platformi u kombinaciji FX-8150 procesora i Asus Sabertooth 990FX R2.0 ploče, napredak je bio izraženiji tek kada smo slabijim grafičkim karticama olakšali posao smanjenjem detalja i rezolucije, dok je kod jače kartice bilo dovoljno smanjiti razinu AA filtera. Kod najjače kartice je napredak bio najizraženiji jer je procesor jednostavno prespor za iskorištavanje njenih punih potencijala.
[ichart headers="ID, FPS" title="Thief (Very Low) @ 1366x768" htitle="FPS" labels="Sapphire R7 240 LP @ Mantle,Sapphire R7 240 LP @ DX11 " values="26.7,25.4" colors="red,green" height="600"]
Kod najslabije kartice na testu nema puno pomoći od Mantlea, ova je igra jednostavno previše za nju, čak i pri najnižim postavkama i niskoj rezoluciji. Ipak, maleni pomak se bilježi.
[ichart headers="ID, FPS" title="Thief (Very High, Tesselation Off, AntiAliasing off) @ 1920x1200" htitle="FPS" labels="Sapphire R7 265 @ Mantle,Sapphire R7 265 @ DX11 " values="46.1,39.4" colors="red,blue" height="600"]
Kada prijeđemo na R7 265 (recenzija uskoro), stvari postaju malo jasnije i Mantle stvarno donosi povećanje igrivosti. Ipak, ovo je primjetno tek kad ugasimo antialiasing filtere te Teselaciju - sve ostale postavke su ipak bile na Very High.
[ichart headers="ID, FPS" title="Thief (Very High, SSAO High, 16xAF) @ 1920x1200" htitle="FPS" labels="Sapphire R9 290 Tri-X @ Mantle,Sapphire R9 290 @ DX11 " values="60.6,41.0" colors="red,blue" height="600"]
[ichart headers="ID, FPS" title="Thief (Very High, SSAO High, 16xAF) @ 2560x1440" htitle="FPS" labels="Sapphire R9 290 Tri-X @ Mantle,Sapphire R9 290 @ DX11 " values="45.4,38.2" colors="red,lightblue" height="600"]
Kada uparimo Havaii Pro čip sa FX-8150 vidimo koliko je on zapravo slabiji te kako ne može iskoristiti pune potencijale ove kartice. Korištenjem Mantlea performanse drastično rastu i tu je njegov pravi benefit - donijeti pomake na jeftinijim konfiguracijama.
Zašto ne zaštedjeti na procesoru a dati malo više novca za grafiku? Do sada je to bio apsurd jer slabiji procesor nikada nije mogao iskoristiti jaku grafičku karticu. Pojavom Mantlea to se mijenja. Najviše će koristi kao što vidimo imati kupci slabijih procesora i jačih grafičkih kartica i to je zapravo odlična vijest. Što bude više Mantle naslova na tržištu, to će igrači sa slabijim konfiguracijama više profitirati!
