Force3D HD4670 vs. Zotac 9500GT AMP!
· · Video · Stranica 6 od 6
Zaključak – Conclusion
Još jednom ćemo napomenuti kako smo svjesno usporedili ove dvije
kartice, premda nisu direktna konkurencija, samo zbog vrlo male razlike u
cijeni. I dok HD4670 relativno zadovoljava performansama, isto se ne može
reći za 9500GT. Ta je kartica jednostavno preslaba za rezolucije više od 1280×1024,
a uz to i nivo detalja ne smije biti visok. Po kvaliteti izrade, dobro riješenom
sistemu hlađenja, solidnom bundleu i OC potencijalu 9500GT AMP! je solidan
proizvod, te je uvjetno preporučljiva ukoliko ste spremni žrtvovati višu rezoluciju
i viši nivo detalja u modernim igrama. HD4670 se s druge strane pokazao kao
vrlo solidan izbor te ima dobar odnos cijena/performanse, no s druge strane
Force3D-ov model pati od loše riješenog sistema hlađenja. Ukoliko Vam to ne
smeta, za malo novaca ćete se moći solidno igrati.
Conclusion
We have to emphasize that two compared cards does not fall into
the same segment, but we compared them because of the small price difference
between them. While HD4670 has satisfactory performances, the same does not
apply to 9500GT. That card is simply too weak for resolutions over 1280×1024,
and at the same time you have to maintain lower level of details. Build quality,
good cooling system, fair bundle and nice OC potential speak in favor of Zotac`s
9500GT AMP!, and we can recommend it on those basis if you are ready to sacrifice
higher game details and higher resolution. HD4670 on the other hand has great
price/performance ratio, but Force3D did a poor job on the cooling system.
If on the other hand that doesn`t bother you, you will get a decent performer
for a low price.
Stranica 6 od 6
