Rezultati testiranja – treći dio
Porast performansi overclockingom
PCMark Core i7-10700K @ OC: 6.433 Core i7-10700K @ OC 6.433 Core i7-10700K: 6.346 Core i7-10700K 6.346 0 7.076
Cinebench 15 Core i7-10700K @ OC: 2.200 Core i7-10700K @ OC 2.200 Core i7-10700K: 2.038 Core i7-10700K 2.038 0 2.420
Cinebench 20 Core i7-10700K @ OC: 5.241 Core i7-10700K @ OC 5.241 Core i7-10700K: 4.936 Core i7-10700K 4.936 0 5.765
Corona Core i7-10700K @ OC: 90 Core i7-10700K @ OC 90 Core i7-10700K: 96 Core i7-10700K 96 0 106
V-Ray Core i7-10700K @ OC: 61 Core i7-10700K @ OC 61 Core i7-10700K: 65 Core i7-10700K 65 0 72
wPrime v2.10 Core i7-10700K @ OC: 78,62 Core i7-10700K @ OC 78,62 Core i7-10700K: 85,27 Core i7-10700K 85,27 0 94
Overclocking je značio porast takta sa 4,7 GHz na 5,1 GHz pri čemu su naravno sve jezgre bile pod opterećenjem. Donijelo je to kao što vidimo i lijep porast ukupnih performansi, a potrošnja je pri tome skočila sa 183 W na 230 W.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM Read Core i7-10700K: 51.964 Core i7-10700K 51.964 Ryzen 3 3300X: 51.794 Ryzen 3 3300X 51.794 Ryzen 7 3800XT: 51.406 Ryzen 7 3800XT 51.406 Core i5-10600K: 51.205 Core i5-10600K 51.205 Core i5-10500: 51.131 Core i5-10500 51.131 Core i5-10400: 51.080 Core i5-10400 51.080 Ryzen 3 3100: 50.948 Ryzen 3 3100 50.948 0 57.160
AIDA64 RAM Write Core i7-10700K: 52.089 Core i7-10700K 52.089 Core i5-10600K: 51.873 Core i5-10600K 51.873 Core i5-10500: 51.767 Core i5-10500 51.767 Core i5-10400: 51.474 Core i5-10400 51.474 Ryzen 3 3100: 28.799 Ryzen 3 3100 28.799 Ryzen 3 3300X: 28.799 Ryzen 3 3300X 28.799 Ryzen 7 3800XT: 27.798 Ryzen 7 3800XT 27.798 0 57.298
AIDA64 RAM Copy Ryzen 7 3800XT: 49.047 Ryzen 7 3800XT 49.047 Ryzen 3 3100: 47.833 Ryzen 3 3100 47.833 Ryzen 3 3300X: 47.758 Ryzen 3 3300X 47.758 Core i7-10700K: 47.125 Core i7-10700K 47.125 Core i5-10600K: 45.223 Core i5-10600K 45.223 Core i5-10400: 43.124 Core i5-10400 43.124 Core i5-10500: 43.081 Core i5-10500 43.081 0 53.952
AIDA64 RAM Latency Core i7-10700K: 43,6 Core i7-10700K 43,6 Core i5-10400: 46,7 Core i5-10400 46,7 Core i5-10500: 46,9 Core i5-10500 46,9 Core i5-10600K: 47,1 Core i5-10600K 47,1 Ryzen 3 3300X: 65,8 Ryzen 3 3300X 65,8 Ryzen 7 3800XT: 67,8 Ryzen 7 3800XT 67,8 Ryzen 3 3100: 70,3 Ryzen 3 3100 70,3 0 77
Izvrsne memorijske performanse s najnižim vremenom pristupa ostvario je Core i7-10700K – odlično.
Potrošnja sistema
Potrošnja i5-7500: 92 i5-7500 92 Ryzen 3 1200: 105 Ryzen 3 1200 105 Ryzen 5 1400: 113 Ryzen 5 1400 113 i7-6700K: 120 i7-6700K 120 Core i5-10500: 124 Core i5-10500 124 Core i5-10400: 125 Core i5-10400 125 Ryzen 3 1300X: 125 Ryzen 3 1300X 125 Ryzen 5 1500X: 130 Ryzen 5 1500X 130 Ryzen 5 1600: 132 Ryzen 5 1600 132 Ryzen 7 1700: 137 Ryzen 7 1700 137 i7-7700K: 138 i7-7700K 138 Ryzen 7 2700: 141 Ryzen 7 2700 141 Ryzen 3 3100: 146 Ryzen 3 3100 146 Ryzen 5 2600: 155 Ryzen 5 2600 155 Ryzen 7 3700X: 160 Ryzen 7 3700X 160 Ryzen 5 3600X: 162 Ryzen 5 3600X 162 Ryzen 7 1700X: 162 Ryzen 7 1700X 162 Ryzen 3 3300X: 163 Ryzen 3 3300X 163 Ryzen 5 1600X: 163 Ryzen 5 1600X 163 i5-8600K: 165 i5-8600K 165 Core i5-10600K: 167 Core i5-10600K 167 Ryzen 5 2600X: 170 Ryzen 5 2600X 170 Ryzen 7 1800X: 173 Ryzen 7 1800X 173 Core i7-10700K: 183 Core i7-10700K 183 Ryzen 7 3800XT: 193 Ryzen 7 3800XT 193 Ryzen 9 3900X: 195 Ryzen 9 3900X 195 i7-6950X: 196 i7-6950X 196 i7-8700K: 200 i7-8700K 200 Ryzen 7 2700X: 201 Ryzen 7 2700X 201 i7-5820K: 205 i7-5820K 205 i7-5930K: 216 i7-5930K 216 i7-7800X: 225 i7-7800X 225 Ryzen 9 3950X: 230 Ryzen 9 3950X 230 0 253
Potrošnja sistema je 183 W pri čemu Ryzen 7 3800XT troši samo 10 W više. Ove brojke ponajprije govore o učinkovitosti kojom rade novi AMD procesori (3800XT je nerijetko brži u multithreadingu) i napredak koji su postigli u iznimno kratkom vremenu. Ne zaboravimo, Core procesori se usavršavaju puno duže od Ryzena.
Zagrijavanje @ Noctua D15
Temperature Core i5-10400: 58 Core i5-10400 58 Core i5-10500: 68 Core i5-10500 68 Ryzen 3 3100: 69,6 Ryzen 3 3100 69,6 Core i5-10600K: 70 Core i5-10600K 70 Core i7-10700K: 71 Core i7-10700K 71 Ryzen 3 3300X: 74,9 Ryzen 3 3300X 74,9 Ryzen 5 3600X: 77,3 Ryzen 5 3600X 77,3 Ryzen 9 3900X: 78,7 Ryzen 9 3900X 78,7 Ryzen 7 3700X: 81,3 Ryzen 7 3700X 81,3 Ryzen 7 3800XT: 83,9 Ryzen 7 3800XT 83,9 0 92
Maksimalna temperatura na jednoj jezgri nakon opterećenja OCCT-ovim Large Data testom iznosi 71°C, a prosjek na svima je 66,4°C. Ovdje je teško uspoređivati dva konkurenta jer Ryzeni drugačije mjere temperaturu od Core procesora, no ono što smo primijetili je da su površinske temperature Noctue D15 vrlo slične.
