Intel Core i9-10850K recenzija
· · Procesori · Stranica 5 od 6
Rezultati testiranja – treći dio
Porast performansi overclockingom
PCMarki9-10850K @ OC: 7.648i9-10850K @ OC7.648i9-10850K: 7.423i9-10850K7.42308.413
3DMark TimeSpyi9-10850K @ OC: 9.932i9-10850K @ OC9.932i9-10850K: 9.873i9-10850K9.873010.925
Cinebench 15i9-10850K @ OC: 2.733i9-10850K @ OC2.733i9-10850K: 2.575i9-10850K2.57503.006
Cinebench 20i9-10850K @ OC: 6.533i9-10850K @ OC6.533i9-10850K: 6.164i9-10850K6.16407.186
Coronai9-10850K @ OC: 72i9-10850K @ OC72i9-10850K: 76i9-10850K76084
V-Rayi9-10850K @ OC: 49i9-10850K @ OC49i9-10850K: 52i9-10850K52057
wPrime v2.10i9-10850K @ OC: 63,956i9-10850K @ OC63,956i9-10850K: 67,975i9-10850K67,975075
Porast performansi overclockingom je solidan i odgovara razlici u porastu takta od +300 MHz.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadRyzen 9 5950X: 68.569Ryzen 9 5950X68.569Ryzen 9 3900XT: 54.188Ryzen 9 3900XT54.188Ryzen 9 5900X: 54.099Ryzen 9 5900X54.099Core i9-10850K: 52.467Core i9-10850K52.467Core i7-10700K: 51.964Core i7-10700K51.964Ryzen 3 3300X: 51.794Ryzen 3 3300X51.794Ryzen 7 3800XT: 51.406Ryzen 7 3800XT51.406Core i5-10600K: 51.205Core i5-10600K51.205Core i5-10500: 51.131Core i5-1050051.131Ryzen 9 5900X: 51.129Ryzen 9 5900X51.129Core i5-10400: 51.080Core i5-1040051.080Ryzen 5 5600X: 50.950Ryzen 5 5600X50.950Ryzen 3 3100: 50.948Ryzen 3 310050.948075.426
AIDA64 RAM WriteRyzen 9 5950X: 53.108Ryzen 9 5950X53.108Ryzen 9 3900XT: 53.064Ryzen 9 3900XT53.064Ryzen 9 5900X: 53.028Ryzen 9 5900X53.028Core i7-10700K: 52.089Core i7-10700K52.089Core i5-10600K: 51.873Core i5-10600K51.873Core i5-10500: 51.767Core i5-1050051.767Core i9-10850K: 51.550Core i9-10850K51.550Core i5-10400: 51.474Core i5-1040051.474Ryzen 3 3100: 28.799Ryzen 3 310028.799Ryzen 3 3300X: 28.799Ryzen 3 3300X28.799Ryzen 9 5900X: 28.781Ryzen 9 5900X28.781Ryzen 5 5600X: 28.729Ryzen 5 5600X28.729Ryzen 7 3800XT: 27.798Ryzen 7 3800XT27.798058.419
AIDA64 RAM CopyRyzen 9 5950X: 64.649Ryzen 9 5950X64.649Ryzen 9 3900XT: 55.684Ryzen 9 3900XT55.684Ryzen 7 3800XT: 49.047Ryzen 7 3800XT49.047Ryzen 5 5600X: 48.992Ryzen 5 5600X48.992Ryzen 9 5900X: 48.489Ryzen 9 5900X48.489Ryzen 3 3100: 47.833Ryzen 3 310047.833Core i9-10850K: 47.789Core i9-10850K47.789Ryzen 3 3300X: 47.758Ryzen 3 3300X47.758Core i7-10700K: 47.125Core i7-10700K47.125Ryzen 9 5900X: 46.859Ryzen 9 5900X46.859Core i5-10600K: 45.223Core i5-10600K45.223Core i5-10400: 43.124Core i5-1040043.124Core i5-10500: 43.081Core i5-1050043.081071.114
AIDA64 RAM LatencyCore i7-10700K: 43,6Core i7-10700K43,6Core i9-10850K: 46,6Core i9-10850K46,6Core i5-10400: 46,7Core i5-1040046,7Core i5-10500: 46,9Core i5-1050046,9Core i5-10600K: 47,1Core i5-10600K47,1Ryzen 9 5900X: 58,8Ryzen 9 5900X58,8Ryzen 9 5900X: 59,1Ryzen 9 5900X59,1Ryzen 9 5950X: 59,8Ryzen 9 5950X59,8Ryzen 3 3300X: 65,8Ryzen 3 3300X65,8Ryzen 7 3800XT: 67,8Ryzen 7 3800XT67,8Ryzen 9 3900XT: 69Ryzen 9 3900XT69Ryzen 3 3100: 70,3Ryzen 3 310070,3Ryzen 5 5600X: 71,2Ryzen 5 5600X71,2078
Propusnost memorije, tj. memorijskog kontrolera je samo prosječna, no zato je latencija i dalje izvrsna.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Core i5-10500: 124Core i5-10500124Core i5-10400: 125Core i5-10400125Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 3 3100: 146Ryzen 3 3100146Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 5 3600X: 162Ryzen 5 3600X162Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 3 3300X: 163Ryzen 3 3300X163Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Core i5-10600K: 167Core i5-10600K167Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 5 5600X: 172Ryzen 5 5600X172Ryzen 7 1800X: 173Ryzen 7 1800X173Core i7-10700K: 183Core i7-10700K183Ryzen 7 5800X: 183Ryzen 7 5800X183Ryzen 7 3800XT: 193Ryzen 7 3800XT193Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205Ryzen 9 5900X: 210Ryzen 9 5900X210Ryzen 9 3900XT: 211Ryzen 9 3900XT211i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 5950X: 225Ryzen 9 5950X225Ryzen 9 3950X: 230Ryzen 9 3950X230Core i9-10850K: 275Core i9-10850K2750303
Potrošnja sistema je mjerena s OCCT-ovim large testom kao i kod ostalih procesora. No, ona je zapravo još i konzervativna, jer primjerice u Cinebench 20 nT testu procesor, odnosno sistem proguta i preko 330 W iz utičnice. Performanse dakle ne dolaze bez penala, u ovom je slučaju to potrošnja. 14-nanometarski proces je ovdje nategnut do kranjih granica.
Zagrijavanje
Temperature (Tdie)G.Skill ENKI 360: 75G.Skill ENKI 36075Gigabyte Aorus Liquid Cooler 280: 78Gigabyte Aorus Liquid Cool…78Noctua NH-D15: 81Noctua NH-D1581089
Uz veliku potrošnju dolazi i više zagrijavanje pa je potrebno i dobro hlađenje za ovaj procesor. Opet navodimo i prosjeke maksimalnih temperatura na svih deset jezgri koji su bolji pokazatelj od samo vršne na jednoj jezgri – ENKI 360 je postigao prosjek od 72,3°C, Gigabyteov hladnjak bio na 73,8°C, a Noctuin na 77°C.
U Cinebenchu 20 se procesor još više zagrijava a koga zanimaju detalji može skoknuti na ENKI 360 recenziju.
Stranica 5 od 6
