Sapphire R9 280X Vapor-X & R9 280 Dual-X
· · Video · Stranica 3 od 6
Rezultati testova – prvi dio
3DMark FirestrikeSapphire R9 280X Vapor-X: 8.063Sapphire R9 280X Vapor-X8.063MSI R9 280X: 7.669MSI R9 280X7.669AMD HD7970 GHz: 7.161AMD HD7970 GHz7.161ASUS GTX770 DCU II OC: 7.078ASUS GTX770 DCU II OC7.078Sapphire R9 280 Dual-X: 6.459Sapphire R9 280 Dual-X6.459Asus GTX680 DCUII: 6.434Asus GTX680 DCUII6.434Sapphire R9 270X Toxic: 6.086Sapphire R9 270X Toxic6.086Asus Striker Platinum: 6.070Asus Striker Platinum6.070Sapphire R9 270X Vapor-X: 5.759Sapphire R9 270X Vapor-X5.759ASUS R9 270X DCU II TOP: 5.685ASUS R9 270X DCU II TOP5.685Gigabyte R9 270 OC: 5.268Gigabyte R9 270 OC5.268Sapphire R9 270 Dual-X: 5.117Sapphire R9 270 Dual-X5.117Sapphire R7 265 Dual-X: 4.645Sapphire R7 265 Dual-X4.64508.869
3DMark pokazuje izvrsne performanse 280X Vapor-X modela, koji malo zaostaje za 280X Toxicom, dok se 280 Dual-X smješta između dvije brze Nvidijine kartice, i iznad 270X kartica.
Bioshock InfiniteASUS GTX770 DCU II OC: 100,77ASUS GTX770 DCU II OC100,77MSI R9 280X: 100,38MSI R9 280X100,38Sapphire R9 280X Vapor-X: 96,70Sapphire R9 280X Vapor-X96,70Asus GTX680 DCUII: 91,37Asus GTX680 DCUII91,37AMD HD7970 GHz: 89,81AMD HD7970 GHz89,81ASUS GTX660Ti DCU II TOP: 87,54ASUS GTX660Ti DCU II TOP87,54Asus Striker Platinum: 83,07Asus Striker Platinum83,07Sapphire R9 280 Dual-X: 78,21Sapphire R9 280 Dual-X78,21Sapphire R9 270X Vapor-X: 75,86Sapphire R9 270X Vapor-X75,86ASUS R9 270X DCU II TOP: 74,77ASUS R9 270X DCU II TOP74,77Sapphire R9 270X Toxic: 74,25Sapphire R9 270X Toxic74,25Gigabyte R9 270 OC: 69,69Gigabyte R9 270 OC69,69Sapphire R9 270 Dual-X: 62,33Sapphire R9 270 Dual-X62,33Sapphire R7 265 Dual-X: 55,88Sapphire R7 265 Dual-X55,880111
Bioshock InfiniteASUS GTX770 DCU II OC: 80,62ASUS GTX770 DCU II OC80,62MSI R9 280X: 75,47MSI R9 280X75,47Asus GTX680 DCUII: 72,85Asus GTX680 DCUII72,85Sapphire R9 280X Vapor-X: 72,55Sapphire R9 280X Vapor-X72,55AMD HD7970 GHz: 67,41AMD HD7970 GHz67,41Asus Striker Platinum: 67,1Asus Striker Platinum67,1ASUS GTX660Ti DCU II TOP: 61,45ASUS GTX660Ti DCU II TOP61,45Sapphire R9 280 Dual-X: 59,32Sapphire R9 280 Dual-X59,32Sapphire R9 270X Vapor-X: 56,09Sapphire R9 270X Vapor-X56,09ASUS R9 270X DCU II TOP: 54,96ASUS R9 270X DCU II TOP54,96Sapphire R9 270X Toxic: 54,92Sapphire R9 270X Toxic54,92Gigabyte R9 270 OC: 51,9Gigabyte R9 270 OC51,9Sapphire R9 270 Dual-X: 46,75Sapphire R9 270 Dual-X46,75Sapphire R7 265 Dual-X: 42,48Sapphire R7 265 Dual-X42,48089
Bioshock daje nešto niže rezultate kod AMD kartica pa su tako sve pomaknute prema dolje u odnosu na druge testove. Ipak, vidimo kako je 280 očekivano iznad 270X modela, a ovo je jedini test gdje je Vapor-X malo sporiji od konkurentnog MSI-evog modela.
Company of Heroes 2Sapphire R9 280X Vapor-X: 57,86Sapphire R9 280X Vapor-X57,86Sapphire R9 270X Toxic: 52,25Sapphire R9 270X Toxic52,25Sapphire R9 280 Dual-X: 49,37Sapphire R9 280 Dual-X49,37Sapphire R9 270 Dual-X: 42,97Sapphire R9 270 Dual-X42,97Asus Striker Platinum: 40,26Asus Striker Platinum40,26064
COH2 je vrlo zahtjevna igra i u ovoj se klasi kartica obavezno mora ugasiti AA filter kako bi imali solidnu igrivost. Zanimljivo, ovdje je 270X Toxic iznad 280 kartice, dok je 280X suvereno na vrhu.
Stranica 3 od 6
