Sapphire R9 280X Vapor-X & R9 280 Dual-X
· · Video · Stranica 5 od 6
Rezultati testova – treći dio
PotrošnjaAMD R9 270X: 290AMD R9 270X290ASUS R9 270X DCU II TOP: 293ASUS R9 270X DCU II TOP293Sapphire R9 270 Dual-X: 320Sapphire R9 270 Dual-X320ASUS GTX660Ti DCU II TOP: 330ASUS GTX660Ti DCU II TOP330Sapphire R9 270X Toxic: 333Sapphire R9 270X Toxic333Gigabyte R9 270 OC: 340Gigabyte R9 270 OC340Sapphire R9 270X Vapor-X: 350Sapphire R9 270X Vapor-X350Asus Striker Platinum: 358Asus Striker Platinum358ASUS GTX770 DCU II OC: 362ASUS GTX770 DCU II OC362Sapphire R9 280 Dual-X: 370Sapphire R9 280 Dual-X370MSI R9 280X: 371MSI R9 280X371Asus GTX680 DCUII: 375Asus GTX680 DCUII375Gigabyte GTX770 OC: 396Gigabyte GTX770 OC396AMD HD7970 GHz Edition: 422AMD HD7970 GHz Edition422Sapphire R9 280X Vapor-X: 425Sapphire R9 280X Vapor-X4250468
Potrošnja Sapphireove 280X Vapor-X kartice je dosta visoka, dok se i 280 pokazala kao rastrošna u onim najzahtjevnijim naslovima.
TemperatureGigabyte R9 270 OC: 60Gigabyte R9 270 OC60Sapphire R9 270X Toxic: 60Sapphire R9 270X Toxic60Asus GTX680 DCUII: 61Asus GTX680 DCUII61MSI GTX770 Lightning: 62MSI GTX770 Lightning62ASUS GTX780 DCU II OC: 62ASUS GTX780 DCU II OC62Sapphire R9 280 Dual-X: 64Sapphire R9 280 Dual-X64Sapphire R9 270 Dual-X: 65Sapphire R9 270 Dual-X65ASUS R9 270X DCU II TOP: 67ASUS R9 270X DCU II TOP67Sapphire R9 270X Vapor-X: 67Sapphire R9 270X Vapor-X67Asus Striker Platinum: 67Asus Striker Platinum67ASUS GTX660Ti DCU II TOP: 68ASUS GTX660Ti DCU II TOP68ASUS GTX770 DCU II OC: 68ASUS GTX770 DCU II OC68Sapphire R9 280X Vapor-X: 68Sapphire R9 280X Vapor-X68Gigabyte GTX580 SOC: 71Gigabyte GTX580 SOC71078
S obzirom na dosta visoku potrošnju rekli bismo kao hladnjaci nemaju lak zadatak, pa je zato Dual-X podešen tako da se vrti na višim okretajima od ostalih Dual-X kartica koje smo probali, te proizvodi buku od 49 dB. Vapor-X je dosta tiši i on radi na oko 46 dB, a pri tome solidno hladi karticu. Ni kod overclockinga se buka znatnije ne diže, a ostavili smo na automatskom profilu.
Stranica 5 od 6
