Rezultati testova – treći dio
Overclocking
3DMark Sapphire R9 285 ITX Compact @ OC: 7.785 Sapphire R9 285 ITX Compac… 7.785 Sapphire R9 285 ITX Compact: 7.147 Sapphire R9 285 ITX Compact 7.147 0 8.564
Hitman Absolution Sapphire R9 285 ITX Compact @ OC: 50,07 Sapphire R9 285 ITX Compac… 50,07 Sapphire R9 285 ITX Compact: 45,79 Sapphire R9 285 ITX Compact 45,79 0 55
Sleeping Dogs Sapphire R9 285 ITX Compact @ OC: 44,4 Sapphire R9 285 ITX Compac… 44,4 Sapphire R9 285 ITX Compact: 41 Sapphire R9 285 ITX Compact 41 0 49
Overclocking performanse su u prosjeku rasle iznad 9% što je solidan rezultat.
Potrošnja
Potrošnja Sapphire R9 270 Dual-X: 320 Sapphire R9 270 Dual-X 320 Gigabyte R9 285 OC: 321 Gigabyte R9 285 OC 321 Sapphire R9 285 Dual-X OC: 323 Sapphire R9 285 Dual-X OC 323 ASUS GTX660Ti DCU II TOP: 330 ASUS GTX660Ti DCU II TOP 330 Sapphire R9 270X Toxic: 333 Sapphire R9 270X Toxic 333 Gigabyte R9 270 OC: 340 Gigabyte R9 270 OC 340 Sapphire R9 270X Vapor-X: 350 Sapphire R9 270X Vapor-X 350 Asus Striker Platinum: 358 Asus Striker Platinum 358 Sapphire R9 285 ITX Compact: 358 Sapphire R9 285 ITX Compact 358 ASUS GTX770 DCU II OC: 362 ASUS GTX770 DCU II OC 362 Sapphire R9 280 Dual-X: 370 Sapphire R9 280 Dual-X 370 MSI R9 280X: 371 MSI R9 280X 371 Asus GTX680 DCUII: 375 Asus GTX680 DCUII 375 XFX R9 280 Black OC: 375 XFX R9 280 Black OC 375 AMD HD7970 GHz Edition: 422 AMD HD7970 GHz Edition 422 Sapphire R9 280X Vapor-X: 425 Sapphire R9 280X Vapor-X 425 0 468
Kartica troši više nego ostale dvije 285 koje smo probali što joj baš i ne ide na čast.
Zagrijavanje
Temperature Gigabyte R9 270 OC: 60 Gigabyte R9 270 OC 60 Sapphire R9 270X Toxic: 60 Sapphire R9 270X Toxic 60 Asus GTX680 DCUII: 61 Asus GTX680 DCUII 61 MSI GTX770 Lightning: 62 MSI GTX770 Lightning 62 ASUS GTX780 DCU II OC: 62 ASUS GTX780 DCU II OC 62 XFX R9 280 Black OC: 62 XFX R9 280 Black OC 62 Sapphire R9 285 Dual-X OC: 63 Sapphire R9 285 Dual-X OC 63 Sapphire R9 285 ITX Compact: 64 Sapphire R9 285 ITX Compact 64 Sapphire R9 280 Dual-X: 64 Sapphire R9 280 Dual-X 64 Sapphire R9 270 Dual-X: 65 Sapphire R9 270 Dual-X 65 Gigabyte R9 285 OC: 66 Gigabyte R9 285 OC 66 ASUS R9 270X DCU II TOP: 67 ASUS R9 270X DCU II TOP 67 Sapphire R9 270X Vapor-X: 67 Sapphire R9 270X Vapor-X 67 Asus Striker Platinum: 67 Asus Striker Platinum 67 ASUS GTX660Ti DCU II TOP: 68 ASUS GTX660Ti DCU II TOP 68 ASUS GTX770 DCU II OC: 68 ASUS GTX770 DCU II OC 68 Sapphire R9 280X Vapor-X: 68 Sapphire R9 280X Vapor-X 68 0 75
Da je hlađenje odlično riješeno vidimo kako se GPU penje samo jedan stupanj celzijev iznad onoga na Dual-X kartici, a sve uz istu razinu buke – odlično.
