RaidSonic Icy Box IB-281U – kućište za gospodu
Datum objave 26.05.2006 - Denis Arunović
Zaključak (conclusion)
RaidSonic je ponovo napravio odlično kućište koje se ističe svojim izgledom, kvalitetom, no i prihvatljivom cijenom od otprilike 160 kn. Premda je kućište teže i veće od konkurencije, ovo su namjeno učinjeni ustupci zbog odabira materijala su ovom kućištu osigurali odličan izgled, ali i visoku razinu robusnosti. USB kabel koji je ugrađen direktno na kućište je velika prednost u odnosu na modele s kojima je potrebno nositi odvojeni kabel. Sve pohvale također idu na računa toga kako je riješeno dodatno napajanje s obzirom da je izbjegnut glomazni AC adapter na taj način da disk po potrebi možete crpiti energiju iz dva USB konektora. No, ništa nije savršeno pa tako ni ovo kućište. Priručnik za instalaciju je mogao biti informativniji, a sama instalacija je mogla biti lakša s obzirom na to da smo za razdvajanje poklopca i kućišta morali rabiti odvijač.
Conclusion in english
RaidSonic again produced an excellent hard drive enclosure which sets itself apart from the competition by quality of build, very stylish looks and acceptable price (about 160 kn in Croatia). Altough Icy Box IB-281U is heavier and bigger than many 2.5-inch enclosures on the market, this was a conscious choice to make the device robust and good looking. Integrated USB cabel is also a big advantage in contrast to regular HDD enclosures with a separate cable. One other thing to praise is the way RaidSonic implemented additional power for the enclosure. Engineers avoided implementing bulky AC adapter. Instead, they added a special USB cabel which can be connected to the primary USB cable so enclosure can, if need be, draw power from two USB ports. Of course, nothing is perfected and this enclosure is not an exception. Installation manual could be little bit more informative and the installation itself could have been easier becuse we had to use straigth screwdriver to split apart lid from the enclosure.
RaidSonic Icy Box IB-281U | |||
Pozitivno + | Dobar izgled i kvalitetna izrada. Integrirani USB kabel. Dodatno napajanje izvedeno preko specijalnog USB kabela (izbjegnut glomazni AC adapter). Priložen softver za backup podataka. Prihvatljiva cijena. | ||
Negativno - | Pomalo glomazno i teško za jedno 2.5" kućište. Priručnik za instalaciju nije previše informativan, a i sama instalacija je mogla biti lakša. | ||
Ocjena |
Ustupili | RaidSonic |
Objavljeno prije 14 minuta
deronjeObjavljeno prije 1 sat
AutomobiliObjavljeno prije 4 sata
Filmovi - dojmovi, komentari i preporukeObjavljeno prije 5 sati
Telemach (ex Tele2)Objavljeno prije 5 sati
P/M: HDD 4TB, SSD-i, DDR4 / DDR3 za laptope i PC, i5 CPU-s, punjači, napajanjaNovosti
Uz kupnju pametnih telefona HONOR Magic7 Pro, HONOR 400 Pro i HONOR 400 stiže i prijenosni aparat za kavu
Ljeto je pravo vrijeme za nove početke, putovanja, spontane avanture i male rituale koji čine svaki dan posebnim. Ove sezone, HONOR je pripremio kampanju koja spaja napredno i ugodno. Uz kupovinu pametnih telefona HONOR Magic7 Pro, HONOR 40... Pročitaj više
10 stvari koje treba učiniti odmah nakon kupnje novog Android telefona
Posjedovanje novog Android pametnog telefona svakako je uzbudljivo jer postoji toliko mnogo mogućnosti prilagodbe. Evo 10 stvari koje trebate učiniti odmah nakon uključivanja uređaja kako biste maksimalno iskoristili mogućnosti personalizac... Pročitaj više
Kineska tvrtka izazvala je groznicu u PC zajednici: lansirala je "ogroman" CPU hladnjak s 4 ventilatora
Nakon serije JF13K, JIUSHARK, kineska tvrtka specijalizirana za razvoj i proizvodnju CPU hladnjaka, nastavlja privlačiti pažnju modelom hladnjaka JF15K Diamond – masivnim dizajnom tornja opremljenim s do 4 ventilatora od 100 mm, hlađenjem d... Pročitaj više
Njemačka traži od Applea i Googlea da izbace DeepSeek iz svojih trgovina aplikacija
Njemačka se pridružila sve većem broju europskih zemalja koje pooštravaju mjere protiv kineskih AI aplikacija – sada traži od Applea i Googlea da uklone DeepSeek iz svojih trgovina aplikacija u Njemačkoj. Njemačka povjerenica za zaštitu pod... Pročitaj više
ASUS ruteri – najbolji izbor za vrhunsko Starlink iskustvo
U Hrvatskoj sve više korisnika prepoznaje prednosti Starlink satelitskog interneta – brzi, stabilni i dostupni internet gotovo na svakom mjestu, bez obzira nalazili se u gradu ili na selu. No, za maksimalno iskorištavanje brzine i pouzdanos... Pročitaj više
