AMD Ryzen Threadripper 2970WX & 2920X recenzija
· · Procesori · Stranica 4 od 6
Rezultati testiranja – drugi dio
Grafičke performanse @ Sapphire Vega 56 8GB
1920×1200
Deus Ex: Mankind DividedRyzen Threadripper 2950X: 78,8Ryzen Threadripper 2950X78,8Ryzen Threadripper 1920X: 78,1Ryzen Threadripper 1920X78,1Ryzen Threadripper 2920X: 70,9Ryzen Threadripper 2920X70,9Ryzen Threadripper 2990WX: 70,4Ryzen Threadripper 2990WX70,4Ryzen Threadripper 2970WX: 66Ryzen Threadripper 2970WX66087
Far Cry 5Ryzen Threadripper 2920X: 87Ryzen Threadripper 2920X87Ryzen Threadripper 2950X: 82Ryzen Threadripper 2950X82Ryzen Threadripper 1920X: 81Ryzen Threadripper 1920X81Ryzen Threadripper 2970WX: 68Ryzen Threadripper 2970WX68Ryzen Threadripper 2990WX: 52Ryzen Threadripper 2990WX52096
HitmanRyzen Threadripper 2920X: 120,96Ryzen Threadripper 2920X120,96Ryzen Threadripper 2950X: 119,79Ryzen Threadripper 2950X119,79Ryzen Threadripper 1920X: 116,88Ryzen Threadripper 1920X116,88Ryzen Threadripper 2970WX: 111,72Ryzen Threadripper 2970WX111,72Ryzen Threadripper 2990WX: 106,82Ryzen Threadripper 2990WX106,820133
29970WX, baš kao ni 2990WX, nije gamerski procesor zbog nižeg radnog takta, pa su rezultati očekivano niski.
S druge strane 2920X je jedino malo podbacio u DeusEX-u, dok je u druga dva naslova na vrhu liste. 2920X baš kao i 2950X po defaultu radi u distributed modu memorijskog kontrolera (UMA), pa smo ga isprobali i u NUMA modu (local), pri čemu su performanse neznatno porasle.
Porast performansi overclockingom
Cinebench 15Ryzen Threadripper 2970WX @ OC: 4.839Ryzen Threadripper 2970WX…4.839Ryzen Threadripper 2970WX: 4.238Ryzen Threadripper 2970WX4.238Ryzen Threadripper 2920X @ OC: 2.726Ryzen Threadripper 2920X @…2.726Ryzen Threadripper 2920X: 2.607Ryzen Threadripper 2920X2.60705.323
V-RayRRyzen Threadripper 2970WX @ OC: 28RRyzen Threadripper 2970WX…28Ryzen Threadripper 2970WX: 32Ryzen Threadripper 2970WX32Ryzen Threadripper 2920X @ OC: 49Ryzen Threadripper 2920X @…49Ryzen Threadripper 2920X: 53Ryzen Threadripper 2920X53058
wPrime v2.10Ryzen Threadripper 2970WX @ OC: 34,954Ryzen Threadripper 2970WX…34,954Ryzen Threadripper 2970WX: 38,556Ryzen Threadripper 2970WX38,556Ryzen Threadripper 2920X @ OC: 62,161Ryzen Threadripper 2920X @…62,161Ryzen Threadripper 2920X: 62,553Ryzen Threadripper 2920X62,553069
Overclocking kod oba procesora donosi porast u potrošnji i zagrijavanju, a to je posebno primjetno kod jačeg. Uz to donosi i određeno povećanje performansi, no zapravo je upitno kolika je korist od toga, jer je potrebno stvarno moćno hlađenje kako bi temperature zadržali u granicama normale. Kod slabijeg za poboljšanje performansi u igrama ni nema potrebe za overclockingom jer one koriste manje jezgri i tada je boost takt ionako preko 4.0 GHz.
Stranica 4 od 6
