Rezultati testiranja – drugi dio
Grafičke performanse @ Gigabyte RX 5700 XT Gaming OC
2560 x 1440
Borderlands 3 (Badass) Core i7-8700K: 62,39 Core i7-8700K 62,39 Core i5-10400: 62,19 Core i5-10400 62,19 Core i5-10500: 61,88 Core i5-10500 61,88 Ryzen 9 3900X: 61,05 Ryzen 9 3900X 61,05 Ryzen 3 3300X: 60,92 Ryzen 3 3300X 60,92 Ryzen 3 3100: 60,86 Ryzen 3 3100 60,86 0 69
F1 2019 (Ultra) Ryzen 9 3900X: 134 Ryzen 9 3900X 134 Core i5-10400: 133 Core i5-10400 133 Core i5-10500: 133 Core i5-10500 133 Core i7-8700K: 133 Core i7-8700K 133 Ryzen 3 3300X: 128 Ryzen 3 3300X 128 Ryzen 3 3100: 125 Ryzen 3 3100 125 0 147
Far Cry 5 (Ultra) Core i5-10400: 101 Core i5-10400 101 Core i5-10500: 101 Core i5-10500 101 Core i7-8700K: 101 Core i7-8700K 101 Ryzen 9 3950X: 99 Ryzen 9 3950X 99 Ryzen 3 3300X: 97 Ryzen 3 3300X 97 Ryzen 9 3900X: 96 Ryzen 9 3900X 96 Ryzen Threadripper 3970X: 95 Ryzen Threadripper 3970X 95 Ryzen 3 3100: 88 Ryzen 3 3100 88 0 111
Ghost Recon Breakpoint (DX11, Ultra) Core i5-10400: 81 Core i5-10400 81 Core i5-10500: 81 Core i5-10500 81 Core i7-8700K: 80 Core i7-8700K 80 Ryzen 9 3900X: 78 Ryzen 9 3900X 78 Ryzen 3 3300X: 77 Ryzen 3 3300X 77 Ryzen 3 3100: 72 Ryzen 3 3100 72 0 89
Ghost Recon Breakpoint (Vulkan, Ultra) Core i5-10500: 86 Core i5-10500 86 Core i7-8700K: 86 Core i7-8700K 86 Ryzen 9 3900X: 86 Ryzen 9 3900X 86 Ryzen 3 3300X: 86 Ryzen 3 3300X 86 Core i5-10400: 85 Core i5-10400 85 Ryzen 3 3100: 84 Ryzen 3 3100 84 0 95
Hitman (Ultra) Core i7-8700K: 119,54 Core i7-8700K 119,54 Core i5-10500: 118,69 Core i5-10500 118,69 Core i5-10400: 118,64 Core i5-10400 118,64 Ryzen 9 3900X: 117,82 Ryzen 9 3900X 117,82 Ryzen 9 3950X: 116,65 Ryzen 9 3950X 116,65 Ryzen 3 3300X: 115,2 Ryzen 3 3300X 115,2 Ryzen Threadripper 3970X: 115,11 Ryzen Threadripper 3970X 115,11 Ryzen 3 3100: 110,56 Ryzen 3 3100 110,56 0 131
The Division 2 (Ultra) Core i5-10400: 65 Core i5-10400 65 Core i5-10500: 65 Core i5-10500 65 Core i7-8700K: 65 Core i7-8700K 65 Ryzen 3 3300X: 65 Ryzen 3 3300X 65 Ryzen 9 3900X: 65 Ryzen 9 3900X 65 Ryzen Threadripper 3970X: 65 Ryzen Threadripper 3970X 65 Ryzen 9 3950X: 64 Ryzen 9 3950X 64 Ryzen 3 3100: 63 Ryzen 3 3100 63 0 72
Najprije slijedi usporedba na višoj rezoluciji, tj. na onoj za koju je i namijenjena RX 5700 XT. Smisao ovoga testa je vidjeti koliko procesor utječe na performanse kada je i grafika već limitirajući faktor. 10400 ovdje pokazuje uzorne performanse i nigdje se ne vidi da će vam faliti snage u odnosu na 10500, pa čak i 8700K te 3900X.
Grafičke performanse pri različitoj brzini radne memorije
1920 x 1200
Borderlands 3 (Badass) Core i5-10400 @ 3.200 MHz: 84,79 Core i5-10400 @ 3.200 MHz 84,79 Core i5-10400 @ 2.666 MHz: 83,59 Core i5-10400 @ 2.666 MHz 83,59 0 93
F1 2019 (Ultra) Core i5-10400 @ 3.200 MHz: 170 Core i5-10400 @ 3.200 MHz 170 Core i5-10400 @ 2.666 MHz: 170 Core i5-10400 @ 2.666 MHz 170 0 187
Far Cry 5 (Ultra) Core i5-10400 @ 3.200 MHz: 113 Core i5-10400 @ 3.200 MHz 113 Core i5-10400 @ 2.666 MHz: 108 Core i5-10400 @ 2.666 MHz 108 0 124
Ghost Recon Breakpoint (DX11, Ultra) Core i5-10400 @ 3.200 MHz: 94 Core i5-10400 @ 3.200 MHz 94 Core i5-10400 @ 2.666 MHz: 89 Core i5-10400 @ 2.666 MHz 89 0 103
Ghost Recon Breakpoint (Vulkan, Ultra) Core i5-10400 @ 3.200 MHz: 108 Core i5-10400 @ 3.200 MHz 108 Core i5-10400 @ 2.666 MHz: 106 Core i5-10400 @ 2.666 MHz 106 0 119
Hitman (Ultra) Core i5-10400 @ 3.200 MHz: 143,63 Core i5-10400 @ 3.200 MHz 143,63 Core i5-10400 @ 2.666 MHz: 138,87 Core i5-10400 @ 2.666 MHz 138,87 0 158
The Division 2 (Ultra) Core i5-10400 @ 3.200 MHz: 90 Core i5-10400 @ 3.200 MHz 90 Core i5-10400 @ 2.666 MHz: 90 Core i5-10400 @ 2.666 MHz 90 0 99
Smisao ovoga testa je vidjeti koliko na performanse utječe brzina radne memorije kada ni procesor ni grafička kartica ne bi smjeli biti prevelik limitirajući faktor. Odnosno, što možemo očekivati od i5-10400 procesora na H470 ploči gdje će vjerojatno ograničenje na brzinu memorije biti upravo na 2.666 MHz kod ovoga procesora.
Razlike kao što vidimo postoje u većini naslova, a samo su F1 2019 i The Division 2 izjednačeni. Tako trebamo biti svjesni da procesor s nižom brzinom memorije neće izvući istu razinu performansi na H470 ploči i na Z490 s bržom memorijom.
