Intel Core i5-10400 recenzija
· · Procesori · Stranica 5 od 6
Rezultati testiranja – treći dio
Memorijske performanse @ 3.200 MHz CL15
AIDA64 RAM ReadCore i7-8700K: 47.016Core i7-8700K47.016Core i5-10500: 46.309Core i5-1050046.309Core i5-10400: 45.290Core i5-1040045.290051.718
AIDA64 RAM WriteCore i5-10500: 46.625Core i5-1050046.625Core i7-8700K: 45.941Core i7-8700K45.941Core i5-10400: 45.710Core i5-1040045.710051.288
AIDA64 RAM CopyCore i7-8700K: 41.892Core i7-8700K41.892Core i5-10500: 38.500Core i5-1050038.500Core i5-10400: 37.647Core i5-1040037.647046.081
AIDA64 RAM LatencyCore i5-10500: 44,5Core i5-1050044,5Core i7-8700K: 49,8Core i7-8700K49,8Core i5-10400: 52,4Core i5-1040052,4058
10400 pokazuje najslabije performanse memorijskog kontrolera od tri procesora, a posebno velika razlika je u vremenu pristupa.
Memorijske performanse @ 3.600 MHz CL16
AIDA64 RAM ReadRyzen 3 3300X: 51.794Ryzen 3 3300X51.794Core i5-10500: 51.131Core i5-1050051.131Core i5-10400: 51.080Core i5-1040051.080Ryzen 3 3100: 50.948Ryzen 3 310050.948056.973
AIDA64 RAM WriteCore i5-10500: 51.767Core i5-1050051.767Core i5-10400: 51.474Core i5-1040051.474Ryzen 3 3100: 28.799Ryzen 3 310028.799Ryzen 3 3300X: 28.799Ryzen 3 3300X28.799056.944
AIDA64 RAM CopyRyzen 3 3100: 47.833Ryzen 3 310047.833Ryzen 3 3300X: 47.758Ryzen 3 3300X47.758Core i5-10400: 43.124Core i5-1040043.124Core i5-10500: 43.081Core i5-1050043.081052.616
AIDA64 RAM LatencyCore i5-10400: 46,7Core i5-1040046,7Core i5-10500: 46,9Core i5-1050046,9Ryzen 3 3300X: 65,8Ryzen 3 3300X65,8Ryzen 3 3100: 70,3Ryzen 3 310070,3077
Oba Intelova se procesora puno bolje snalaze s visokom brzinom memorije, pa je prava šteta što je ovakav 3.600 MHz kit vrlo skup i zapravo neisplativ za nabavku pored takvih zaključanih procesora.
Potrošnja sistema
Potrošnjai5-7500: 92i5-750092Ryzen 3 1200: 105Ryzen 3 1200105Ryzen 5 1400: 113Ryzen 5 1400113i7-6700K: 120i7-6700K120Core i5-10500: 124Core i5-10500124Core i5-10400: 125Core i5-10400125Ryzen 3 1300X: 125Ryzen 3 1300X125Ryzen 5 1500X: 130Ryzen 5 1500X130Ryzen 5 1600: 132Ryzen 5 1600132Ryzen 7 1700: 137Ryzen 7 1700137i7-7700K: 138i7-7700K138Ryzen 7 2700: 141Ryzen 7 2700141Ryzen 3 3100: 146Ryzen 3 3100146Ryzen 5 2600: 155Ryzen 5 2600155Ryzen 7 3700X: 160Ryzen 7 3700X160Ryzen 5 3600X: 162Ryzen 5 3600X162Ryzen 7 1700X: 162Ryzen 7 1700X162Ryzen 3 3300X: 163Ryzen 3 3300X163Ryzen 5 1600X: 163Ryzen 5 1600X163i5-8600K: 165i5-8600K165Ryzen 5 2600X: 170Ryzen 5 2600X170Ryzen 7 1800X: 173Ryzen 7 1800X173Ryzen 9 3900X: 195Ryzen 9 3900X195i7-6950X: 196i7-6950X196i7-8700K: 200i7-8700K200Ryzen 7 2700X: 201Ryzen 7 2700X201i7-5820K: 205i7-5820K205i7-5930K: 216i7-5930K216i7-7800X: 225i7-7800X225Ryzen 9 3950X: 230Ryzen 9 3950X2300253
Potrošnja sistema s 10400 procesorom je vrlo slična onome s 10500 zbog razloga koje smo naveli ranije. STRIX ploča duže forsira visoke taktove pogotovo na benchmarcima i Large Data postavci OCCT-a. Samo za usporedbu na uključenom MCE i sa Small Data potrošnja raste na 160W.
Zagrijavanje @ Noctua D15
TemperatureCore i5-10400: 58Core i5-1040058Core i5-10500: 68Core i5-1050068Ryzen 3 3100: 69,6Ryzen 3 310069,6Ryzen 3 3300X: 74,9Ryzen 3 3300X74,9Ryzen 5 3600X: 77,3Ryzen 5 3600X77,3Ryzen 9 3900X: 78,7Ryzen 9 3900X78,7Ryzen 7 3700X: 81,3Ryzen 7 3700X81,3089
Zagrijavanje pod Noctuom D15 je nisko, i čak 10°C niže nego kod 10500. Kada ga umjesto s Large Data, “stisnemo” sa Small Data u OCCT-u temperatura raste na maksimalnih 63°C za jednu jezgru.
Stranica 5 od 6
